These surfaces share a common line of edge points. They are both degree 3 surfaces
join query.3dm (685.4 KB)
Why won’t they join?
Hello- I would just move the single control point at the tip of the red decking to the end of the blue surface edge that is right there - that is the only thing out of whack.
Thank you Pascal. I should have found that. I spent literally an hour searching and researching for the problem and, as usual, it turns out to be finger trouble.
Kind regards,
Hugo.
maybe mark pascals answer as solution - there is a checkbox below the post - so others don t need to dig into the topic. … happy modelling -tom
Hi Hugo - CrvDeviation or EdgeContinuity > Position can help in these cases - showing where the biggest gap is.
Thank you Pascal. I have never used these commands before. Using them would certainly have saved me a lot of time and prevented me from showing my ignorance ![]()
