Why Kangaroo accumulate data
I try to figure out how to prevent from the data (points) accumulate in the Kangaroo solver. It keeps any move of the slide…
drag test.gh (15.3 KB)
Any suggestions ?
Cheers.
How many accounts do you use at the same time?
Yes, try to keep everything on the same thread.
Anyway, kangaroo is not meant to be used as you are doing.
Particles should be defined before the start of the simulation, if the particle amount change or their start location change, you are supposed to reset the simulation.
yea, sorry for that… I posted it from the pc, and it has a different account for some reason and I didn’t notice that till too late…
Thanks for your answer.
Yea, I guess I do try to push the limits of it… is there any other method/ plugin that has anything similar to GRAB, that can move GH elements on the Rhino canvas?
try this
but I still think you should find a workflow that lets you drag rhino object in rhino space, and only after do your thing in gh…
