Hello- it will sometimes fail to trim if there is more than one closed region - your curve going across touches the outer curve on both ends? Just use that outer curve to trim when you’re done . It might be interesting to test whether shortening that middle curve by just a tiny bit (SubCrv command) lets the Patch trim as you expect.
