White isocurves won't change color
Am I missing a simple fix? I changed layer color to black, then clicked the object, and set display color to “by layer”. The surface edges show black, but the isocurves remain white - arrgghhh! Where is the setting to change isocurve color by object/layer/color, etc.,etc.? Or should isocurve inherit color from the surface - or edge?
Block 08.3dm (693.6 KB)
If you fix it, please explain how - thanks!
Hi Carl,
You have “per face colours” applied. Select the whole model and run _RemovePerFaceColors.
HTH
Jeremy
BINGO!
Thank you!!!
