White hatch printing black in B&W mode
The screenshot below shows two PDFs, the top one has the Output Color set to Print Color, and the bottom has it set to Black & White.
On the left is text above a hatch with a white display & print color.
On the right is is a closed extrusion with a green display color and a white print color.
Both are are in shaded view mode, with rectangles below both objects.
Since the fill of a 3D object doesn’t honor the print color, I would like to just print using Black & White, however when I do that, white hatches show up as black.
Is this the intended behavior, and is there any work-around? my goal is to be able to show a mix of 3D objects and 2D location tags in a plan view, using hatches like a region or wipeout in AutoCAD.
thanks!
The only work-around I’ve found is to print in color, then convert it to B&W in Acrobat’s Preflight.
Is this the intended behavior though? Seems odd for a white fill to print in black.
Hi Paul -
I see this and put it on the list as RH-69172.
Thanks,
It looks like this is still an issue in version 8, where white hatches are printing as black when selecting black & white.
I saw the comments on jetbrains about using a non-rectangular detail, but I don’t understand that suggestion.
The other reason I’ve found it helpful to be able to print in black & white while using hatches as wipeouts is when working with backgrounds from other people. Often they’ll have a lot of nested blocks with object colors not set to layer, so the only way to set print colors would be to explode everything.
thanks -
Paul
