Hİ
When you press Standard. The toolbar is not changed _RH8
I noticed there is a difference between the icons
Rhino 8 SR2 2023-11-21
Thanks.
Hİ
Thanks.
Please
@Gijs
With the standard tab selected in the main toolbar, click on the settings gear at the right end and select properties. The popup should look something like this:
If the Sidebar isn’t showing Main you can change it by clicking on the paperclips (a tooltip will show what each does). If it does show Main then the problem lies deeper…
