Hello, wondering if any1 has done any research on what the latest AI tools are for grasshopper rhino. Lets make this a topic about AI and Grasshopper. How are people using AI in their modeling/designs? Are people making custom components using gpt to code? Are people translating all their long grasshopper scripts to python or C++ using gpt to make everything under 1 component? Some ideas.
When I search this forum I find very little topics on AI + grasshopper + architecture design. Looks like AI is being used more for just rendering. Feel free to share render tools too.
Whats the latest ChatGPT type plug in?
Anyone have any cool leads, articles, videos, tutorials, extensions, plug ins?
I am in the middle ground.
Use AI for coding to build tools not output.
Yes, converting large swathes of Grasshopper spatial operations into compact Python nodes. My own 3D math and python capabilities will never equal the output that Claude and Cursor are able to deliver.
*(To be honest, there is a tension to publicly acknowledging using AI for coding. I should be able to code better. I should know matrix translations. There is an imposter syndrome aspect to it. It is a very productive coding process, but I don’t want to be one of those “AI FOMO guys” that talks about it like their first experimentation in university, with myopic glowing evangelism.
I don’t want my output called into question due to perceived AI taint.
This judgment structure probably affects others, being judged as less capable for taking a shortcut that is surrounded by current hype context.
I do not expect a big discussion uptake here from those using LLM tools., and personally don’t expect to say much more on the subject.)
Try out SmartHopper, an open-source AI assistant that is fully integrated into the Grasshopper canvas. And this plugin is more than just a chat assistant; it also includes many new AI-powered components for performing small operations on native Grasshopper data, lists, etc., opening up a new world of possibilities. Please share your thoughts at: SmartHopper - A deeply integrated AI assistant for Grasshopper
Shameless plug: Worth mentioning Runchat’s Grasshopper plugin here too. Runchat takes a different approach from Raven/Ant. Rather than writing GH definitions for you, it adds nodes that connect Grasshopper to external AI services directly on the canvas.
So you get components for image generation (Nanobanana, Flux, SDXL, etc.), text-to-3D mesh (Trellis, Hunyuan3D), code generation where an LLM writes RhinoCommon scripts and web search all wired into your existing parametric definitions.
Runchat plugin is free, you can BYO api keys for Gemini / Fal, install from PackageManager or more info here: docs.runchat.com/plugins/grasshopper
