What settings control pixelation and banding of rasters in V8?
Hi
V8
cant get these images bigger its 3x that in reality, silly image handling here. you will have to imagine it bigger !
Normally one can click and get a separate image display window which then allows a click again for ACTUAL SIZE, but thats not available, why not ?
Having been working on a OBJ with rasters in V5, then opened it into V8, the same areas are visually poorer.
Agisoft metashape has a problem wherein it makes blurred areas when the photos are pin sharp (or at least no where near as bad, such a shame and makes working on the meshes much harder in those areas !)
I have to work through that, however V8 is making it worse with pixelation and banding.
What settings do I adjust to get it as V5 ?
I was also hoping for a faster workflow, project a circle to the mesh V8 16 secs V5 18 secs.
Not quite the speed I was after as every projection is taking that long and I have hundreds to do.
Again what settings will speed that up as its going to take forever.
The save in V5 was 1min 30secs, hope with compression turned off (not even an option in V5) it will be VERY quicker. 20secs v 2mins was a previous test.
Cheers
Steve
You probably have flat shading on, which doesn’t draw geometry smoothed:
I’ll take a look and report back
Cheers
Steve
If its a texture problem, you could try the “enable filtering” option in your texture settings in the material panel. I sometimes work with pixel textures and I had the opposite problem, where pixels would get blurred together when I rescaled the image.
@nathanletwory
Flat Shading is OFF, so not the cause
@Roman_Mamus
and in MATERIALS I cant see the suggested setting.
here is my V5 setting for comparison.
Default settings should deliver at least as good as V5.
Steve
Help…need solve this mess.
anyone ?
(nothing is straightfwd with V8, i.e nothing works off the bat, one hurdle after another)
Just want to get operational not solving issue after issue.
have work to do !
Steve
Have you checked if “Enable Filtering” is turned on within the Bitmap Texture Setting?
see my image of the materials tab settings, is that where the bitmap setting is ?
I couldnt find the setting referred to .
I also run the textures command and here are the settings, where is that setting ?
Cheers
Steve
Try this, the little funnel icon:
Consider that this may blur the textures depending upon the mapping. But it’s worth a try.
@Steve1 it looks to me that filtering in Rhino 5, even when switched off, is rendering the same as when turned on. So turning the filter on in Rhino 8 is the only way to get the same look as what you see in Rhino 5
@Gijs
I clicked that filter button bit no change occurred.
so what else can I try ?
You have the file there at McNeel, so have a play.
Steve
The file you sent, it’s the texture of material 002, did you change the texture for that material?
when in V5 I imported the obj for layer called No Ruler V2 (the obj name is in the layer),
I browsed to the jpg for that obj, and allocated it.
This V5 file was later imported into V8, and as documented, the texture failed to show properly, that file was saved anyway.
so in V8 I then went file open and opened the V5 file instead and it came in looking correct.
I selected that mesh and went edit copy, then opened the wonky V5 into V8 import file, deleted the wonky mesh layer, and pasted that mesh in. then it looked correct.
and thats the jpg.
I selected that mesh and went to that filter and nothing changed.
I havent allocated a different jpg, that would have no reason behind it and would give me a wrong mesh appearance.
It is the jpg that was generated by Agisoft for that obj on layer V2 No Ruler.
Its the same jpg in V8 as is shown is use in V5, and V5 doesnt pixelate it..
McNeel have both the original V5 file and the V8 with the V5 imported and showing wonky mesh.
Not sure if I sent the fixed one, dont think I did, but follow the dead easy method above to make one ! then compare the V5 to the V8.
HTH.
Steve
works here:
