coming from V5, I was used to using 0.3 and Print Preview to get a slightly thicker line, and 0.5 a bit thicker, visually noticeably thicker, with 1.2 well and truly thick enough to differentiate.
In V8 I have got as far as the max normally offered of 2.0 and its more like 0.5.
zoom in and its 0.1inch thick.
what does the number refer to ?
where is the setting to make it as V5 ?
also I normally get a shock as its HUGE, compared to V5.and I want to reduce it.
so whats going on ?
I would wish for the units to be the units of the document.
so if using mm, 0.5 would be 0.5mm.
2 obviously is not 2inch., being 0.1inch I struggle to understand those numbers at all.
Steve
