Creating a rectangular surface with a diagonal line, then flowing the diagonal line onto the cone also works. Result is essentially the same as Spiral. Spiral Flow Steve.3dm (2.0 MB)
Of course you are right. I spoke too soon. I was imagining âprojectingâ parallel to the coneâs base (perpendicular to its axis). But as you show thatâs not how the project command (or, for that matter the pull command) works
If you are talking about the final turn of a thread on a bolt, I believe you will find that the helix radius stays constant to the end. The reason that a casual glance leads you to think the final turn spirals in is that the end of the bolt has a chamfer that progressively cuts away more of the top of the V as you get closer to the end.
So to get the effect, make a solid bolt, then make a cutter by boolean differencing a cone from a cylinder and then boolean difference the cutter from the bolt.
Hi Jeremy,
aha !
I have seen videos of folk sweeping the curve in
an apparent Rhino tutor ?
and took that as to be the need, and theur method was criticised but no mention of the fact that it wasnt needed at all. However what you show makes such as they do unnecessary.
My brain says if metal moves inwards the helix would remain out in space, however your image shows that as not the case.
I must do what you show to see it for myself.
we need a definitive guide to bolt thread making !
I then look at the other end of the thread and see they have milled around the thread and it simple gets milled or ground/turned, whatever one would call it, out of existence without going inwards.
My item has the thread vanishing just before the slope starts, or perhaps its a tad up the slope, so a bit of experimentation moving the slope up and down is needed.
Try and find a large bolt such as an M20, then use your vernier (assuming the edges are sufficiently feathered) to measure the diameter at the base of the thread at several points along the length, including near the very end and you should see it remains pretty constant.
You should also see a video on how a thread is created in a thread turning operation on any CNC machine. To me, moving the helix in, while aesthetically âcorrectâ, breaks the reality of how your underlying geometry definition is produced. Even on a proper higbee thread, the tool that turns or thread rolls the helix doesnât just âbite downâ at the end. Infact, they often taper outwards (at the screw/bolt head end), the opposite of what the modelling strategy may be by crushing the helix.
