Ideally the piece below would wrap around a solid as a ribbon-like form. Please advise. I’ve tried various combinations of sweeps and spirals and twists without success.twist:spiral.3dm (3.6 MB)
Hi there,
Yes, partially as in the photo. Thank you, I will give that a try.
helix2.3dm (3.4 MB)
So I thought your suggestion made sense but had unfortunate results when I attempted. Could you break it down a bit more for the twist around part of the curve?
As in a step by step approach to get the result that you got.
tx!
Thanks so much, that worked!
Now to complicate things, is there a way to flow objects along the closed polysurface created by the helix and then sweep1? Been trying with arraysrf but am having trouble.
