I have done some research and I cannot find the function to “Hide Objects in Detail” or “Show Objects in detail”
For example, I have a few geometries in Rhino, I have square, triangle and circle.
I want to have a Layout of each geometry.
So I create the layout for “Square” first, then create a view, then in the view, I have to hide triangle and circle.
At the moment, I can create the layout, but I cannot seem to find the function to “Hide Objects in Detail” …
dale
(Dale Fugier)
July 29, 2016, 3:31pm
#2
Hi Toby,
I don’t see a way of this yet. But you can always script these commands.
I’ve added a wish list item:
http://mcneel.myjetbrains.com/youtrack/issue/RH-34998
– Dale
I know this is an old post but I was wondering if this had been implemented yet?
I have been doing this as a workaround but its rather slow and clunky and I would love to replace it.
string cmd = "-_HideInDetail ";
foreach (Guid id in ids)
cmd += "_SelID ";
cmd += id.ToString() + " ";
cmd += "_Enter ";
RhinoApp.RunScript(cmd, false);
I see @stevebaer referenced in a pull request for January of this year. Let me know when it is live in version 6.
Thanks,
dale
(Dale Fugier)
May 23, 2018, 3:28pm
#4
Thanks, I’ll give that method a try!
jake1
(Jake)
January 28, 2020, 3:51pm
#6
Hi Dale,
Are there any example that use AddHideInDetailOverride?
It does not seem to be working for me and it does not have any errors.
When I step through the code, I am calling the AddHideInDetailOverride, but the objects are still shown in the detail view.
if (docLayer.IsVisible) {
// hide layer objects in detail
var layerObjects = _doc.Objects.FindByLayer(docLayer);
foreach (var layerObject in layerObjects) {
ObjRef layerObjRef = new ObjRef(layerObject);
RhinoObject obj = layerObjRef.Object();
obj.Attributes.AddHideInDetailOverride(detail.Id);
jake1
(Jake)
January 28, 2020, 4:13pm
#7
I guess I should add that I am looping through multiple details and only showing objects that are on a particular layer or its parent / child layers.
The code is called on all layers that are not parents, children or the selected layer for each detail.
I don’t know if that may have some affect on the result. It is hard to see where the AddHideInDetailOverride attributes are stored for each object.
dale
(Dale Fugier)
January 28, 2020, 4:41pm
#8
Hi @jake1 ,
Here is a full-featured example:
SampleCsHideInDetail.cs
– Dale
jake1
(Jake)
January 28, 2020, 4:55pm
#9
That helps a ton! Thank you.
