What is the difference between Explicit attribute vs @Property in Python?
import Rhino
import scriptcontext
class Geometry(object):
    # Explicit attribute:
    geo_color = "green"
    # Property:
    @property
    def color(self):
        return self._color
    @color.setter
    def color(self, value):
        self._color = value
class Line(Geometry):
    def Draw(self, Point1, Point2):
        # draw line ...
        pass
line = Line()
line.geo_color = "white"
color = line.geo_color
print line.geo_color
print color
Hi @onrender,
There are a number of important differences between “properties” and “member access”.
The most significant is that you can, through a property, make a member read-only (you can access the state, but you cannot change it).
You can also return a computed value from a property (generate a value “on-the-fly”, as though it were a variable).
I’m sure there is more…
https://docs.python.org/3/tutorial/classes.html
– Dale
