Python property decorators in Rhino?
class TestLine:
def init(self,x):
self.x = x
@property
Dear community,
I’m trying to work with so-called python properties, as in the example below.
def x(self):
    return self.__x
@x.setter
def x(self, x):
    if x < 0:
        self.__x = 0
    elif x > 1000:
        self.__x = 1000
    else:
        self.__x = x
if name==“main”:
t = TestLine( 3 )
print "x = " + str(t.x)
t.x = -12
t.x = 1207
print "Finished..."
The result should be due to the defined getter and setter property that
x = 3
x = 0
x = 1000
Finished…
However, the result shown is
x = 3
x = -12
x = 1207
Finished…
So it seems as the setter and getter properties are bypassed and the private __x is not used but just a public x is used instead.
The example is from a Python 3 tutorial… Which python version is supported by Rhino? Or is the problem still somewhere else?
Many thanks in advance.
Kind regards,
Filip
OK, never mind.
Seems to be an issue with old-style and new style class definitions:
