Storing calculations inside class with python
I want to create a class with a number of related properties which are calculated inside the class when certain property is assigned but I can not make it…
python code below is a simplified version of my class, which does not work as expected
two values displayed on the end should not be the same, but they are…
what am I doing wrong ?
thanks in advance…
class Test:
    def __init__(self,obj=None):
        self.Object=obj
        self.Volume=0.0
        self.m3=0.0
    def Volume(self):
        return self.Volume
    def Volume(self,x):
        self.Volume=x
        self.m3=x/1000000000
    def m3(self):
         return self.m3
def m3():
    obj = rs.GetObject()
    T = Test(obj)
    vol = rs.SurfaceVolume(obj)[0]
    T.Volume =vol
    print vol
    print T.m3
return
m3()
Hi @AleksandarSM,
Maybe something like this?
import Rhino
class VolumeHelper(object):
    def __init__(self, obj = None):
        self.m_object = obj
        self.m_volume = Rhino.RhinoMath.UnsetValue
        self.m_m3 = Rhino.RhinoMath.UnsetValue
    def IsValid(self):
        rc = isinstance(self.m_object, Rhino.DocObjects.RhinoObject)
        if rc:
            rc = Rhino.RhinoMath.IsValidDouble(self.m_volume)
        if rc:
            rc = Rhino.RhinoMath.IsValidDouble(self.m_m3)
        return rc
    @property
    def Volume(self):
        return self.m_volume
    @Volume.setter
    def Volume(self, val):
        self.m_volume = val
        self.m_m3 = val / 1000000000
    @property
    def M3(self):
         return self.m_m3
def TestVolumeHelper():
    filter = Rhino.DocObjects.ObjectType.PolysrfFilter
    rc, objref = Rhino.Input.RhinoGet.GetOneObject("Select closed polysurface", False, filter)
    if not objref or rc != Rhino.Commands.Result.Success: return rc
    obj = objref.Object()
    if not obj: return
    brep = objref.Brep()
    if not brep: return
    if not brep.IsSolid: return
    volume_helper = VolumeHelper(obj)
    volume_helper.Volume = brep.GetVolume()
    if volume_helper.IsValid:
        print(volume_helper.Volume)
        print(volume_helper.M3)
if __name__ == "__main__":
    TestVolumeHelper()
– Dale
Hello Dale,
I tried your example but it does not calculate the M3 property correctly., similar to mine
This time I get M3 value -1.23432101234e+308 regardless of the selected solid, which is the default value for the property
BR
Aleksandar
– Dale
Continuing the discussion from Storing calculations inside class with python:
Thanks a lot!
I didn’t understand at first, but then then I found this article on the subject:
https://stackoverflow.com/questions/42258224/difference-between-class-foo-class-foo-and-class-fooobject
and it is all clear now. - in Rhino we have (Iron)Python 2.xx…
BR
Aleksandar
