How should I select a single segment of a polyline?
Thanks
Rachel
Thanks
Rachel
I’m not 100% sure if this works on polylines, but try Ctrl+Shift to activate sub object select.
ExtractSubCrv will extract a single segment of a polyline or polycurve. http://docs.mcneel.com/rhino/5/help/en-us/commands/extractsubcrv.htm
Thank you both very much !!
The option of Ctrl+Shift doesn’t work.
The ExtractSubCrv command works fine.
Thanks
Rachel
This works in V6/WIP, just fyi, but only as a selection within a polyline, not to extract the segment.
