Which list component is this? It’s not in sets?
List item
No unfortunately not. List item has an L. This is an E. With a List and wrap input, just like list index.
Old version of List Item
Fullname: MathComponents.ArrayComponents.Component_ListItem_OBSOLETE_ASWELL
Defined : MathComponents, Version=6.7.18177.12461, Culture=neutral, PublicKeyToken=dda4f5ec2cd80803
Dynamically loaded
Comp ID : 285ddd8a-5398-4a3e-b3c2-361025711a51
Inst ID : 902c7618-37bd-4eb6-8264-82acf2eb1d0c
Implemented:
Grasshopper.Kernel.IGH_ActiveObject
Grasshopper.Kernel.IGH_Component
Grasshopper.Kernel.IGH_PreviewObject
Grasshopper.Kernel.IGH_BakeAwareObject
Grasshopper.Kernel.IGH_RenderAwareObject
Grasshopper.Kernel.IGH_InitCodeAware
Inherited from:
Fullname: Grasshopper.Kernel.GH_Component
Defined : Grasshopper, Version=6.7.18177.12461, Culture=neutral, PublicKeyToken=dda4f5ec2cd80803
Stored : C:\Program Files\Rhino 6\Plug-ins\Grasshopper\Grasshopper.dll
Fullname: Grasshopper.Kernel.GH_ActiveObject
Input parameter(s):
L: List
Base list
Expected type: IGH_Goo
i: Index
Item index
Expected type: GH_Integer
W: Wrap
Wrap index to list bounds
Expected type: GH_Boolean
Output parameter(s):
E: Element
Item at {i'}
It might be a custom cluster. GH icons are available and sometimes people -including me- use them for their own user objects…
You don’t have the definition? (or at least the full image?)
It is old one before list item had a ZUI output. you can find it by searching #listitem although you don’t need it if you just use the current list item.
It is list item
means you are doing something else wrong. Post your definition.
Thanks very much for your time. Below is my definition.
I haven’t included the points or curves but they should really be universal.
The point of the exercise is to morph lines in panelling tools without having to loft in rhino.
Thanks again for your time.
PTATRACTOR.gh (6.4 KB)
