Weird little GH bug -- empty string converts to Rhino Curve
Thought I was doing something unholy as usual, but instead found a bizarre #gh3d bug. Try it: Run an empty item into a Curve parameter input, and it converts into the first crv in the RhinoDoc! GH 1.0.0007. Real monkey wrench if you’re not paying attention…
Oh, by the way, it works with Breps as well – probably with any geometry type? These seems to be a generic casting error.
Ah, it’s trying to find a Rhino object with the same name. A bug indeed, it shouldn’t have tried with an empty string.
Logged under RH-54605 now.
RH-54605 is fixed in the latest Rhino 7.8 Service Release Candidate
