Weird elefront errors when opening VA file
after updating to latest release version, i get these errors on project load.
Its weird, because I dont use elefront, this file is just a visual ARQ project no grasshopper involved.
what is wrong here…
Hi @ng5_Alex,
As far as I know, we haven’t made any changes to the VisualARQ Grasshopper Components. Are you certain these errors didn’t occur in the previous version?
In any case, I recommend contacting Elefront support, as we’re unable to debug issues within Elefront’s code.
Thanks,
Enric
Like i already said, i do not use elefront. I uninstalled it, warnings went away.
Still, if i was a developer i would be interested to understand, why an external plugin that is not used by a user tries to cache a wall style block from my plugin, and gives a warning about it.
But i am not so case closed.
This is what I think is happening:
  • Elefront is a Grasshopper add-on.
  • VisualARQ loads Grasshopper at startup because we use it to generate geometry for some VisualARQ objects.
  • When Grasshopper starts, it automatically loads all Grasshopper add-ons, including Elefront.
  • Elefront is doing something with the block definitions in the document. (The names with long UUIDs that you see in the error messages are just Rhino block definitions that exist in the VisualARQ templates).
  • Elefront probably has a problem when it is loaded too early. This is not the first add-on we’ve seen with a bug like this, and normally this is an issue in the add-on itself, not something we can fix on our side.
Thank you for the explanation.
Ok then, i understand and in the future i will not be reporting such cases, where other add-ons are giving errors.
eleFront dev here.
eleFront does indeed cache block definitions at load time, as well as when you open a new file, etc. This enables multiple features, such as being able to visualize the blocks in Grasshopper, indicating whether a block definition exists only in Grasshopper or also in your document, and so on.
I haven’t come across any issues with eleFront being loaded too early. From these error messages, the errors indicate invalid geometry in the blocks: an extrusion with no profile shape, a Line with only one end point, etc.
Obviously if you aren’t using it, uninstalling it is a good call, but hopefully this is useful additional context for others.
Hello @krahimzadeh ,
thank you for your answer and the details given. To be more precise i use elefront, i have not used it in this VA project. In order to troubleshoot i uninstalled it, not because i thought elefront gives errors, it is obvious to me from the warnings, that elefront identifies the errors.
It seems reasonable to have maybe invalid geometry in section view blocks, i can imagine for example a zero length curve or something similar.
But getting bad blocks from furniture and walls styles seems like something i would examine, which if i get the time i will do, using the guids, and report back for future reference.
best
alexandros.
I also use elefront and I also get the errors @ng5_Alex mentioned above.
