Hello everyone, I made a previous topic about this before but I believe my initial problem may be due to a bug.
I have here a Closed SubD. It’s about 1,5 meters from the world origin. When i clip it using a standard clippingplane, the cut generates nicely. However, it only does so when I cut it along the top-view-plane. Whenever i try to move or rotate my clippingplane, Rhino does not generate nice cuts. Instead, the clippingplane-intersection becomes all jagged and weird, not to mention that the cut does not fill. Instead, it shows my SubD as a hollow shape.
Here’s what it’s supposed to look like, nicely generated edges/cuts.
Here’s what it looks like when I rotate the clippingplane. Same position, same shape, same everything, just a rotated clippingplane 90-degrees.
I’m on rhino for Mac right now, should be the latest version. But i can make sure to test this again on Windows to see if the problem persists.
Thanks.
