Hello
ClippingPlaneObject.GetFillSurfaces
don’t give result when the geometry is SubD,
in Rhino works well.
Grasshopper
Rhino
Hello
Grasshopper
Rhino
Hi @anon39580149,
Can you post a .gh file that demonstrates the problem you are seeing?
Thanks,
– Dale
Hi @dale
This is a file, just reference the geometries and add clipping plane to Rhino
cplane subd.gh (4.8 KB)
I’ll have to look into what to do to get the intersection code used to work with SubD.
Until then you’ll have to convert subds to breps before using the utility function.
