Weird behavior of Vector Printing (v8 SR26)
Using Rhino v8 SR26 on windows 11
I am having trouble printing using Vector Output. My layout views are set to Technical. When using Raster output, it matches the layout perfectly but when using Vector output i get weird issues:
  • Text located behind 3d objects are showing through even after using the ClearDrawOrder command
  • HideInDetail objects are sometime shown, some hidden objects are also shown in broken wireframe
Above is a screenshot taken in the print preview using raster output
here is using vector output
Is there any workaround to get a matching print using vector output?
I should add that if i set my detail views’ display mode to wireframe or shaded it works fine.
Thanks!
Hi Louis Roy,
Can you post the file as well as your complete SystemInfo? Thanks!
Hi Japhy,
Thanks for the quick response. Here is the file and my system info:
VectorOutput_Issue_LouisRoy.3dm (5.7 MB)
Rhino 8 SR26 2025-12-15 (Rhino 8, 8.26.25349.19001, Git hash:master @ c6182b1b71af690bf339ed38f9ccfc2fec2e46c3)
License type: Commercial, build 2025-12-15
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 15GB)
.NET 8.0.14
Primary display: AMD Radeon™ Graphics (AMD) Memory: 1GB, Driver date: 8-13-2024 (M-D-Y).
Integrated accelerated graphics device with 5 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA GeForce RTX 4050 Laptop GPU (NVidia) Memory: 6GB, Driver date: 11-24-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 566.26
Integrated accelerated graphics device with 4 adapter port(s)
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-24-2024
Driver Version: 32.0.15.6626
Z-Buffer depth: 24 bits
Total Video Memory: 6141 MB
C:\Users\###\AppData\Roaming\McNeel\Rhinoceros\BlockEditNew\BlockEditNew_V8.rhp “BlockEdit” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.26.25349.19001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.26.25349.19001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.26.25349.19001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.26.25349.19001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.26.25349.19001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.26.25349.19001
Thanks for reporting RH-91155 Vector Printing not respecting Hide in Detail
I was able to Print correctly in Rhino 7 if that helps.
any update on this? Experiencing same bug w Technical View Vector Print ignoring HideInDetail objects. would be amazing to get this solved as for architectural and engineering tasks Technical Vector Prints in combination w. Hide/Show for specific details is a real time-saver.
Hi hans, seeing this in the Beta as well. I’ve added that as affected versions to ensure it gets attention.
