Watch cuve
hgvdfsbds fewaqFe. rtewTEW
could you post your input curves or anything you started with?
i believe the corners or the entire boundary curve might be produced with a continuos control point curve, if the surface is not entirely created by such surfaces anyway. so creating a curve according to the coordinates might not make much sense to start with i assume.
Thank you for your reply!
This are the curves that i created following the apple spec. Used also for the sweep 1 rail.
What I think is that I should have another internal curve to use it as a second rail. But the thing is that if i do the offset, the curve created doesn’t follow the input curve.
When I saw the title I thought maybe you were going to ask if Rhino would run on an Apple Watch. :slightly_smiling_face:
Not an answer but don’t forget that Rhino is able to import the PDF
here the PDF link, question on page 276
hahahaha would be nice
Yes thank you! I already imported but the curves are not accurate.
