I just installed R6 without uninstalling R5 first, and right away this happened multiple time, is this a bug or is rhinoscript.rhp no longer needed?
Edit: after starting R6 and I try to manually load RhinoScript.rhp inside the preference, and got the error below:
Any idea what’s going on?
Best,
wim
(Wim Dekeyser)
August 9, 2018, 10:58am
2
Not really…
Could you post the result of the Rhino SystemInfo
here?
Just to be clear - how exactly did you try this?
I did it by went into Tools > Options > Plugin > right click on “Rhinoscript” > click “Load Plug-in”
I just opened Rhino again the error showed up but after I went in to check inside options it is loaded this time. When it’s not loaded, is it the reason why my rhinoscriptsyntax method will not work like MultiListBox?
below is my SytemInfo result, thank you in advance:
Rhino 6 SR4 2018-5-10 (Rhino 6, 6.4.18130.19341, Git hash:master @ 51190de75f80526c68ef8bdf62938fe1eb6ccc8a)
Licence type: Commercial, build 2018-05-10
Windows 10.0 SR0.0 or greater (Physical RAM: 64Gb)
Machine name: CH-PC0LP223
Quadro M2000M/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 388.75)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 12-20-2017
Driver Version: 23.21.13.8875
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands”
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\Rhino.Log.rhp “Rhino.Log”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI”
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles”
C:\Program Files\Enscape\Bin64\Enscape.Rhino6.Plugin.dll “Enscape.Rhino.Plugin”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars”
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros 6\VRayForRhino.rhp “V-Ray for Rhino”
KeithR
August 9, 2018, 3:33pm
4
