Want split brep by curve
please help me to divide this brep by curve..
I can’t able to split it . i tried split brep multiple but can’t able to make it
Maybe try splitting by another Brep not Curve. so I think you can try extend the curve into brep like cutting plane but like cutting brep. And see if any boolean operation can work.
Or rather, you can try cut the top and bottom circles into smaller curve segment and do NetworkSrf to generate the surface one by one in Rhino
Try Surface Split!
It is not Surface it is brep
Deconstruct the Brep into its faces via Deconstruct Brep, Surface Split and reconstitute to a BRep via Brep Join
but I dont know how to shatter the circle with points. shatter comannd needs parameter as in it is not taking points to shatter curve so what can I do
You need to provide a file instead of just a screenshot.
:roll_eyes:
Want split brep by curve VR 01.gh (12.3 KB)
Much improved performance with Pull Point
Want split brep by curve VR 02.gh (27.4 KB)
You can just feed the Brep into the Surface Split component:
As an aside, note how the sphere’s seam causes one element to be split in two - I’ll leave you to decide how to place the seam to prevent this…
Avoiding the seam accounts for half of the component work in my script above.
