Which function of the RhinoCommon or RhinoScriptSyntax should use to implement splitting a surface by the curve which lays on the surface (the same functionality as the Split tool in Rhino, where the cutting object is a curve and the object to split is a surface)?
sadovshikov
(Vitaly Sadovshchikov)
1
diff-arch
(diff-arch)
2
You can use this:
Related topics
| Topic | Replies | Views | Activity | |
| Splitting brep by curves fails in RhinoCommon but not in Rhino | 9 | 167 | March 10, 2026 | |
| Curve.Split Method | 3 | 636 | October 13, 2021 | |
| Splitting a surface with multiple surfaces | 2 | 856 | February 8, 2019 | |
| Splitting Surface with Curve using brep.Faces.split not working | 2 | 1095 | December 30, 2019 | |
| Splitting a Brep by a curve (rhinocommon) | 2 | 2231 | March 5, 2015 |
