I would like to have wall intersections and ends where the external material wraps to the full thickness of the wall style. I haven’t been able to find a way to do it. The 2 top plans in image bellow present what I can achieve by playing with the wall parameters. The bottom plans is what I would like to have. Note that the intersection is between two different wall styles.
Hi @Filipe_Brandao I’m not sure if it is possible to achieve that result. Just in case, can you send the 3dm file with these wall styles and situation?
Hello @fsalla. Yes I can share privately the model. Where should I send it to?
Just send it to visualarq@asuni.com. It doesn’t need to be a full model, just one with those two walls.
