Hello, can I rotate (single) walls around x or y axis? If yes, how can I rotate it. Rotated walls jump always back to the former position when I use gumball or a rotation tool. Can I create walls in an other viewport or can I use a construction plane?
Dirk
Hello @memo_design1,
Walls can only be rotated around Z axis because they need to be vertical. Why do you need to rotate them around X or Y axis?
Yes, you can create walls in any viewport. Walls are created in the active construction plane, which you can define manually or using the Level manager.
Yes it is helpful to be able to make a sloping or slanted wall. These can happen for various reasons. It could be part of a retaining wall, part of a sloped curtain wall, a decorative wall panel, or a number of other reasons.
While we develop a feature which allows the creation of slanted walls you can create them by making a Rhino polysurface and running the _vaWallFromSolid command.
