Hi @Calcman the default wall connection can’t be edited, and it’s based on the wall styles that join. Two walls with the same style join with “Mitter” type. Walls with different styles join with “Butt” type. Would you like to change that behavior?
I am currently trying VA and considering if its useful for digital fabrication purposes, and in this regard the butt connection is the type i need. I will see if i can use different wall styles as a workaround. Would it be enough to name them differently?
Hi @Calcman, yes, if walls have a style with a different name (eventhough the other attributes are the same), the default join will be Butt.
In the previous post, I forgot to mention that in Grasshopper it is not possible to edit the wall joints. The wall intersections are not actually being calculated there (for performance reasons), so you can only edit the joint after baking the walls, from the Properties panel:
