Hi, I’m currently using Rhino 7 trial and Vray for rhino to render my project. This doesn’t usually happen on the vray where the render result looks very pixelated, almost like being covered by frosted glass. Is there any settings that I have to check? Attached is the screen capture, hopefully I can get it fixed asap, thank you!
Your object is too far from the world origin. If you move it close to the origin I’m quite sure this issue resolves.
easyy! resolved. thanks so much!!
