ali.dlg3
(Ali Dlg3)
February 8, 2018, 6:10pm
1
Hello!
I’m struggling with a voronoi structure
I’m trying to build a Voronoi structure for a arm cast, I already tried several approaches but I cant manage to build the structure in the mesh
Does anyone have a solution for this?
I would be very thankfull
Did you seek a bit on forums ?
Dear all,
I am trying to create a loft surface between curves created with voronoi. The end result should be a personalized model for a 3D printed arm cast. The problem now is that I cannot create any kind of surface between the curves. Do one of you know how I should solve this problem?
I also added the arm STL file I am using for the personalized cast.
arm.stl (6.9 MB)
[image]
ArmToCast_Chien_CONCEPT2.gh (549 Bytes)
Hi there , do you guys know how to apply a Voronoi on a polysurface ?.I found a video on how to do it on surface, but my object is a poly surface, it is a arm 3d model and I want to make a hand cast with voronoi patern , but can’t figure it out how on polysurface…and to make that hand cast as a surface it’s giving me a headache.
Here is the movie about voronoi on surface : voronoi on surface
Here is something similar that I want to achieve [image]
Here is my polysurface :arm1.3dm (4.0 MB)
T…
[image]
If you break your arm and need a cast you typically have friends write personal messages on the cast. Now there’s an app for that: app #CAST, created by the Fathom design team. But instead of a plaster cast covered with ink, the messages form the cast itself.
The messages are gathered from personal wishes collected through social networks. The arm (orleg) is scanned. The characters are fit to form the custom cast. The unique cast is printed in breathable nylon material and delivered …
hey Jeff than you so much , well I used contour command with small distance between , then I rebuild the curves - then I add some points to the last curves and manually put them close together to form that thumb , the best way I think is to use _interpCrvonsrf like you told me but for now I will leave it as it is ,thx again for your time and effort to help me .
Best regards Alex
Here is what i’ve done so far [image]
bdw do you know a good way to offset a mesh , when I use the offset command …
