Hello
This is the first proyect that I am making in Rhino/grasshopper, so I really apprecieate If someone can give me some advice
I am trying to make an arm cast, with a voronoi surface. I scanned an arm and made a surface from it in Rhino.
The arm cast consist in two pieces that will be joined, the thing with the voronoi structure is that if I apply the code of gh in my surface and cut the solid I will be cutting through holes and that will make my cast less resistent, so I though of cutting the arm surface in a half ( I managed to do It with the Contour and Trim commands using a intersection plane) and apply the gh code on both surface
The problem gets when I applied it, because gh make my voronoi structure as if the surface of the arm were complete ( It is like I didn’t cut it at all)
If someone can orientate my I would be very gratefull
Thank you
Morphed Voronoi_re.gh (48.2 KB)
s2.3dm (1.4 MB)
s1.3dm (2.3 MB)
2703.3dm (16.2 MB)
