Voronoi 2D Error
I’m having a problem with the 2D Voronoi in grasshopper. The Voronoi component is creating an extra cell in some cases without a input point. Sometimes it’ll be overlapping cells, other times it will create a random cell within another. Oddly, the Voronoi 3D component seems to be working fine. does anybody know a reason for this?
I’ve attached some pictures below and a file with the data.
2D Voronoi (example 1)
3D Voronoi (example 1)
2D Voronoi (example 2)
3D Voronoi (example 2)
File : Voronoi error.gh (18.1 KB)
With a random move it seems to suppress the problem
So the problem is surely a numeric problem with “perfectly” aligned points
Maybe you have duplicate points
There is a cull duplicate before this, but even in that case there should still be a point within the ‘random’ cell I think
Thanks for this solution, seems to have fixed it. Still weird that this is an issue in the first place
Use the Bounding box as Boundary
This seems to work as well, but still doesn’t resolve the reason to why it happens
@DavidRutten is this a numerical error within the voronoi component?
