Volume command ignores extrusions in blocks
Can we trust software which tells you all this selected and highlighted timber is only 0,2m3 ?
It seems it cant compute block instances volume!
Rhino 8 SR5 2024-2-27
No file and no system info?
bad volume blocks bug.3dm (678.6 KB)
Rhino 8 SR5 2024-2-27 (Rhino 8, 8.5.24058.13001, Git hash:master @ eaa901528453bac5a3cfc23321bdf4d767238d34)
License type: Commercial, build 2024-02-27
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 16GB)
.NET 7.0.17
Computer platform: LAPTOP - Plugged in [91% battery remaining]
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 2-25-2020 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1050 Ti with Max-Q Design (NVidia) Memory: 4GB, Driver date: 11-21-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 546.26
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-21-2023
Driver Version: 31.0.15.4626
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\ivan_galik\Downloads\blockeditnew20231220\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.5.24058.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.5.24058.13001
Rhino ignores the extrusions in your file.
volume_command_ignores_extrusions_in_block.3dm (628.6 KB)
It seems like your problem occurs when objects inside of your block’s definitions are extrusions.
It works better when they’re polysurfaces.
Can we change the topic title to this:
‘Volume command ignores extrusions in blocks’
I did but this is really fatal error.
Hi Ivan -
Thanks, I’ve put this on the list → RH-81079 Volume: Issue with extrusions in blocks
@wim As this issue is a regression with potentially serious concequences for anyone relying on the Volume results for engineering calculations I assume it will soon have a stop ship or similar priority
RH-81079 is fixed in Rhino 8 Service Release 6 Release Candidate
