System Info
Rhino 8 SR7 2024-3-28 (Rhino 8, 8.7.24088.06001, Git hash:master @ f39d2478d0e77eb325f46d0c6d8cfc8754fe44b2)
License type: Commercial, build 2024-03-28
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 64GB)
.NET 7.0.11
Primary display and OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Primary OpenGL: NVIDIA RTX A3000 12GB Laptop GPU (NVidia) Memory: 11GB, Driver date: 2-15-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 551.61
Secondary graphics devices.
Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 2-15-2024
Driver Version: 31.0.15.5161
Z-Buffer depth: 24 bits
Total Video Memory: 11520 MB
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\24.2.0.0\bella_rhino.rhp “Bella” 24.2.0.0
C:\Users\Czaja\Desktop\Rhino_7_Win_2023.0417\HDRLightStudioTexture.rhp “HDRLightStudioTexture”
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\Crayon (39629248-4fa6-47b8-83c7-745a7efea259)\1.2.0.0\Crayon\Crayon.rhp “Crayon” 1.0.0.0
C:\Users\Czaja\AppData\Roaming\McNeel\Rhinoceros\BlockEditNew\BlockEditNew.rhp “BlockEdit” 1.0.0.0
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Datasmith Rhino Exporter (d1fdc795-b334-4933-b680-088119cdc6bb)\DatasmithRhino7.rhp “Datasmith Exporter” 5.4.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.7.24088.6001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.7.24088.6001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.7.24088.6001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.7.24088.6001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.7.24088.6001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.7.24088.6001
I wrote “large” in quotation marks because I don’t really know what is a large Rhino file. I have ~ 1000 Block Definitions that ironically were made to keep my file small & fast. Reusable geometries are in the form of nested block structures and despite the fact there are a lot of Block Instances in the file, it only weighs 94 MB.
I had many challenges that led me to do some things just for a test and I need to recreate/swap some geometries.
In my file, Block Definitions consist of geometries put on different layers, one layer “ShrinkWrap” has shrinkwrapped geometries that have been done in a draft quality and I would like to replace them with better geometries. I’ll just list all the things out.
I can’t normally remove ShrinkWrap meshes using Grasshopper because of problems with some components. Using data dam, and disabling troublesome components thankfully does the job as a workaround.
Looking for the right Rhino 8 build - #5 by Czaja -
I can’t delete the ShrinkWrap layer from the Layers Panel, because this move is forbidden in Rhino. The ShrinkWrap layer doesn’t have any Block Instances, but geometries inside Block Definitions are on that layer. I would be saved if, after some serious warnings, I could simply delete this layer and thus remove geometries from the Block Definitions. (error shown in the video)
Block Manager is dead slow and unusable even when just filtering data! Mind you that at this point I’m not modifying anything I’m just using the search in the panel. I made a critical error of not assigning names to all ShrikWrap meshes so it doesn’t matter anyway because I can’t use a search to filter them out.
It’s nice that the new Block Manager in Rhino 8 is showing the contents of the blocks but it’s done in a way that is not suited for large projects. Every property is shown underneath the Block Definition / Objects list, there is no way for good grouping/filtering/sorting and making batch changes.
not the best way to display properties for multiple objects and make batch changes
I guess it’s ok when we have only a few Block Definitions but when dealing with a large number all the data should be accessible from the table/property matrix. I know Block Definitions can form a nested structure, but it should be possible to display all the objects in a flat list with the help of the “parent” column.
I mentioned it elsewhere, probably you know how large amounts of data can be shown in a flat list but if not, please take a look at Directory Opus. There is no problem at all in transforming nested structures into a flat list and making all sorts of grouping possible while maintaining a good understanding of the structure.
Directory Opus excelent ways of showing nested folder/file structures and search results
Unreal Engine Property Matrix (02:03) - The large number of elements is especially noticeable when working in game engines
If Block Manager could display a flat list of data I could:
a) In this specific case - Use a filter in a “Layer” column to select all objects on a “ShrinkWrap” layer and simply delete them.
b) Batch change any exposed property value of any number of objects.
c) Use multiple column filters to filter out stuff in a custom way and highlight objects in the viewport.
d) Greatly enhance my understanding of what’s going on in the file and make it possible to make changes from the table.
e) Export table out of Rhino.
I understand that many of these will not be implemented tomorrow, but I expect that at least the search bar should work properly.
Video is boring because it shows mostly unbearable UI freezes
