VisualArQ. Toggle Cut Plane Issues with other Clipping planes
Hi Again!.
Well. today I noticed that the Toogle Cut PLane is not working anymore as expected.. (you can see in the video that some objects remain visible. it fails now to “cut” the objects (leaving for instance this walls with a gabbled roof at the end of the video are evident).. Any suggestions to solve this?
Thank you in advance for your support.
Rhino 8 SR37 2026-10-21 (Rhino 8, 8.37.26294.11001, Git hash:master @ a6592128d921cf5111f81ead500d1035845fda34)
License type: Educational, build 2026-10-21
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 31GB)
.NET 10.0.2
Computer platform: LAPTOP - Plugged in [99% battery remaining]
Primary display: AMD Radeon™ 780M (AMD) Memory: 1GB, Driver date: 10-18-2026 (M-D-Y).
Integrated accelerated graphics device with 5 adapter port(s)
  • Windows Main Display is laptop’s integrated screen or built-in port
    Primary OpenGL: NVIDIA GeForce RTX 4060 Laptop GPU (NVidia) Memory: 8GB, Driver date: 8-20-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 616.56
Integrated accelerated graphics device with 4 adapter port(s)
  • Video pass-through to primary display device
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-20-2026
Driver Version: 32.0.16.1656
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\ProgramData\D5 Lite for Rhino\engine\D5Conv.Rhino8.rhp “D5 Live Sync for Rhino”
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\VisualARQ.rhp “VisualARQ”
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\Bella (813de3fb-18eb-405f-bfcd-b0b4d3da91fb)\25.3.0.0\bella_rhino.rhp “Bella” 25.3.0.0
C:\Program Files\Rhino 8\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.37.26294.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoBonusTools.rhp “Rhino Bonus Tools”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.37.26294.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.37.26294.11001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.37.26294.11001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.37.26294.11001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.37.26294.11001
C:\Program Files\Rhino 8\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 8.37.26294.11001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.37.26294.11001
C:\Program Files\Rhino 8\Plug-ins\NamedPositions.rhp “Named Position”
(just an update.. I see that the problem is that the Toggle Cut Plane has this issue when there are other clipping planes active in that viewport).. so I rename the topic
Hi @mutarq The Clipping Planes and VisualARQ Cut Planes should be compatible. You can section a model by combining a VisualARQ Level Cut Plane, a VisualARQ Section and a Rhino Clipping Plane.
I can see you have set a boundary to the building. Take into account that only the parts of the objects inside the boundary will be clipped by the Level Cut plane.
You can also check whether the objects that are not sectioned have their “Clippable” status checked or not:
If you still think there’s still an error here, please share the file and we will investigate it further.
