Hi, I just came to the conclusion that in my configuration VA (the latest build) disables Enscape’s capabilities of updating the geometry in real-time. I tested many Rhino configurations until I uninstalled VA and now Enscape works just fine.
The issue was happening with native rhino geometry as well as with VA geometry
I have been testing it and it works fine in my computer. Please, try to install VisualARQ again to check if you can reproduce the error again after installing it.
If you still can reproduce it, could you send a video of how you are doing it? Just in case I am following a different workflow…
