VisualARQ 3 nested blocks crash
Thanks for the good work on the VisualARQ 3 version!
I discovered that putting VARQ objects inside a block and then copying the block crashes Rhino. Inserting the block works fine.
Hi @studioselva thanks!
I can’t reproduce that crash with blocks. Are you using the Copy command? or Ctrl+C/V? Is that happening in Rhino 7 or Rhino 8? Can you share a sample file so we can reproduce the crash?
I’ve sent you an example file. The problem occurs when I use the Copy command, not Ctrl+C/V.
Got it, thanks! I could reproduce the crash with your file! I’ll get back to you when we fix it.
I’d like to know when this is fixed also. Thanks.
@studioselva @djhg we have just published a new update that fixes this crash.
I’m sorry, but it’s still crashing if I try to copy the block in the sample file.
Hi @studioselva you are right. I think we tested this in a wrong internal version. We will publish a new update with this error fixed asap.
@studioselva @djhg we have just uploaded a new update (3.0.13) on the website, with this error fixed: Update - VisualARQ (please ignore the 3.0.11 number in that page)
It works perfectly now. Thank you for the incredibly fast solution!
