Visual bug with rotated blocks in 'shaded' viewports?
Hi, I’ve been bugged by a visual glitch in shaded view just recently whereby rotated blocks show differently in the shaded viewport.
Here’s a clip of a clean file where I’ve created a row of boxes.
I make one of those boxes a block and array it. It can be seen at that point that the two rows are identical.
However, I then create a copy of the block and rotate it 180 degrees with the gumball.
It is immediately apparent that the block is visually different, and the effect persists when I array it.
It would appear the problem relates somehow to the gradient that creates the illusion of shading based on angle to the camera, for whatever reason it is inverted or has its centre offset or something, really not sure. I’ve not noticed it before so I’m guessing its an R8 thing.
Any comments appreciated. It’s distracting when I have an array of, say, windows on a facade, and on one wall they show differently, I’m also quite visual and use my layer colours a lot to comprehend what’s going on.
SystemInfo
Rhino 8 SR17 2025-3-7 (Rhino 8, 8.17.25066.07001, Git hash:master @ b14fcd901289f8715631debb308bc919a4988e07)
License type: Educational, build 2025-03-07
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Primary display: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-16-2022 (M-D-Y).
Primary OpenGL: NVIDIA Quadro P600 (NVidia) Memory: 4GB, Driver date: 7-23-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.76
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-23-2024
Driver Version: 32.0.15.6076
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V8\VRayForRhino.rhp “V-Ray for Rhino”
C:\Program Files\Enscape\Enscape.Rhino.Plugin-net48\Enscape.Rhino8.Plugin.dll “Enscape.Rhino8.Plugin” 4.4.0.452
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.38.192\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.38.192.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.17.25066.7001
C:\Users\Dan\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.17.25066.7001
C:\Program Files\Rhino 8\Plug-ins\MeshTools.rhp “MeshTools”
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.17.25066.7001
Your video drivers are pretty old. I would suggest updating them.
Hiya, thanks for the rec, I’ve now done so
But unfortunately I’m still getting it
I also disabled my Ladybug, V-ray and Enscape
I’m guessing this is just me? this isn’t behaviour you see on your machine?
System readout now as follows (note that whilst my p600 has a recent driver, the UHD 630’s most recent release was 2022):
SystemInfo
.NET 7.0.20
Primary OpenGL: NVIDIA Quadro P600 (NVidia) Memory: 4GB, Driver date: 3-14-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 572.83
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Driver Date: 3-14-2025
Driver Version: 32.0.15.7283
Hi Dan -
This was fixed in Rhino 8.18.
RH-86448 Display: Color artifacts in blocks
you can also turn on Use advanced GPU lighting in the shading settings - this should fix it
Ah thanks, one of those problems with many possible names and I didn’t see it had already been raised, great it’s been fixed
(I can confirm it’s fixed)
