In the first image, the display mode is set in realistic where the section is placed and the hatch is visible
But in the second image, the display mode is set in pen rendered mode and I did turn on the clipping plane settings
Hi @Vasanth_C,
VisualARQ section attributes doesn’t work yet in display modes that use the technical pipeline, like “Technical”, “Artistic” or “Pen”.
Regards,
Enric
thanks @enric I found an alternate solution for that, I downloaded ‘artic with lines’ display mode from food for rhino which does a fair job but I still would go for visual arq section attributes since you guys are working on line weights in section. The result would be so professional. Thank you. visualARQ is so nice
