There is an issue with visibility since the recent update (I think). While moving around the viewport some objects turn into a wireframe, and it fixes itself after. It makes moving around pretty difficult. I think the issue acts up when I have a polysurface set on a custom display mode (arctic, rendered, ghosted, or costume), which is a feature I used to use often.
The file is even smaller than it was before, so its not an issue because of size/complexity. I have also tried it on different newer files and the same issue keeps on happening.
Please let me know, if anyone has a solution. I ran SystemInfo command and posted the result below.
Hi Giorgi - the first thing to try is to disable Enscape (Rhino 8 menu > Settings > Plug-ins page), completely quit Rhino and then re-open Rhino to see if the problem remains.
