Hi @Dan40
First thing to do, is to run the SystemInfo command in Rhino and post the resulting text here - that might give an indication on what’s going on. Usually missing/misbehaving UI elements are due to old graphics drivers.
HTH, Jakob
External USB display device with 7 adapter port(s)
Windows Main Display attached to adapter port #0
Primary OpenGL: D3D12 (Qualcomm(R) Adreno™ X1-85 GPU): Microsoft Corporation. OpenGL Ver: 4.6 (Compatibility Profile) Mesa 26.2.0-devel (git-c1445345a4)
No graphics device is being used for OpenGL
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Microsoft Corporation
Render version: 4.6
Shading Language: 4.60
Driver Date: 1-8-2026
Driver Version: 31.0.137.0
Z-Buffer depth: 24 bits
Total Video Memory: n/a
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\Pollination\1.70.8\net8.0-windows\Pollination.RH.Loader.rhp “Pollination.RH.Loader” 1.70.8.0
C:\ProgramData\McNeel\Rhinoceros\packages\8.0\LadybugTools\1.40.70\net8.0-windows\Ladybug.RH.Loader.rhp “Ladybug.RH.Loader” 1.40.70.0
Hi @Dan40
I believe that GPU belongs to an ARM processor (correct me if I’m wrong), which is not supported by Rhino, cf. the system requirements from the Rhino3d.com website. “Not supported” doesn’t necessarily means it won’t run, but there will likely be problems like the one you are seeing, if it does run.
