Viewport Flicker on Selected Objects
Rhino 8 SR0 2023-10-5
System Info
Rhino 8 SR0 2023-10-5 (Rhino 8 BETA, 8.0.23278.13004, Git hash:master @ ef9b91f9bd9105fc36db6b03c7d47d3fd68a6bc6)
License type: Educational, build 2023-10-05
License details: Cloud Zoo
Expires on: 2023-11-19
Apple macOS Version 13.5.2 (Build 22G91) (Physical RAM: 32Gb)
Mac Model Identifier: MacBookPro18,2
Language: en-AT (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1 Max
Color LCD (1728 x 1117 @ 120.00Hz)
USB devices
GenesysLogic: USB3.1 Hub
Logitech: USB Receiver
USB C : USB C Video Adaptor
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/Applications/RhinoWIP.app/Contents/PlugIns/import_modelio_macos.rhp “Model IO Import” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_glTF.rhp “Import glTF” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ShrinkWrap.rhp “ShrinkWrap” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_glTF.rhp “Export glTF” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_USD.rhp “Export USD” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_DGN.rhp “MicroStation file import: import_DGN” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_E57.rhp “E57 Import” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/MPlane.rhp “MPlane” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Squish.rhp “Squish” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_M.rhp “Import_M” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_X.rhp “X Import” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_STL.rhp “STL Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_STL.rhp “STL Import” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_Points.rhp “Points Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X.rhp “X Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_Points.rhp “Points Import” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 8.0.23278.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.0.23278.13004
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.0.23278.13004
hi @atair Can you send that model, or a minimal example? I just logged bug regarding line quality, and it would be good to check if this is the same issue, thanks
Can’t reproduce it anymore… worked on the file on windows yesterday - openend it again to isolate you a piece, but it does not flicker anymore.
Will revive this thread if it shows up again
