Hi @John_Brock
[Yes I wouldn’t expect it to show on an intel Machine.]
Since posting, Iv’e updated to the [secondary] WIP build came out this morning : 8.0.23186
The issue seems a little bit less pronounced on it then last night build, but it still significantly there. Better described as the visual affect of the components on the canvas becoming blurred [and a bit flickering too] when panning the canvas.
System info:
Summary
Rhino 8 SR0 2023-7-5 (Rhino WIP, 8.0.23186.12306, Git hash:master @ a1ea879a58479b90068dee6bbb99c5b5c1622775)
License type: Commercial, build 2023-07-05
License details: Cloud Zoo
Expires on: 2023-08-19
Apple macOS Version 13.4.1 (Build 22F82) (Physical RAM: 96Gb)
Mac Model Identifier: Mac14,6
Language: en-TH (MacOS default)
Apple M2 Max (OpenGL ver:4.1 Metal - 83.1)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Apple
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 72 GB
Graphics: Apple M2 Max
Displays: Unknown (255dpi 2x)
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M2 Max
Color LCD (1728 x 1117 @ 120.00Hz)
USB devices
Generic: USB3.0 Card Reader
VLI Inc.: USB 2.0 BILLBOARD
Wacom Co.,Ltd.: Wacom Intuos Pro M
3Dconnexion: SpaceMouse Enterprise
VIA Labs, Inc. : USB Billboard Device
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/Users/akashlotan/.rhinocode/python3.9-30/libpython3.9.dylib
/Users/akashlotan/.rhinocode/python3.9-30/lib/python3.9/lib-dynload/_heapq.cpython-39-darwin.so
/Users/akashlotan/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/bella_rhino.rhp/libbella_dotnet_native.dylib
/Users/akashlotan/Library/Application Support/McNeel/Rhinoceros/packages/8.0/IntelDenoiser/0.6.7/libtbb.12.dylib
/Users/akashlotan/Library/Application Support/McNeel/Rhinoceros/packages/8.0/IntelDenoiser/0.6.7/libOpenImageDenoise.1.4.3.dylib
/Users/akashlotan/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/bella_rhino.rhp “Bella” 23.3.0.0
/Applications/RhinoWIP.app/Contents/PlugIns/import_modelio_macos.rhp “Model IO Import” 8.0.23186.1002
/Users/akashlotan/Library/Application Support/McNeel/Rhinoceros/packages/8.0/IntelDenoiser/0.6.7/IntelDenoiser.Mac.rhp “IntelDenoiser.Mac” 1.0.0.0
/Applications/RhinoWIP.app/Contents/PlugIns/MPlane.rhp “MPlane” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_STL.rhp “STL Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ShrinkWrap.rhp “ShrinkWrap” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_DGN.rhp “MicroStation file import: import_DGN” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRoslyn.rhp “RhinoRoslyn” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_Points.rhp “Points Import” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_Points.rhp “Points Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_X.rhp “X Import” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_STL.rhp “STL Import” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCPython.rhp “RhinoCPython” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_USD.rhp “Export USD” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_glTF.rhp “Export glTF” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_X.rhp “X Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Squish.rhp “Squish” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/import_E57.rhp “E57 Import” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_glTF.rhp “Import glTF” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 8.0.23186.12306
/Applications/RhinoWIP.app/Contents/PlugIns/Import_M.rhp “Import_M” 8.0.23186.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 8.0.23186.12306
Thanks a lot
Akash
