viewcaptureToFile - saves .png instead of .jpg (bug)
(mac only bug(?))
_viewcaptureToFile
→ check Transparent Background
→ Rhino will save a .png instead
the old behaviour was to save a .jpg with white background - which was very nice i think. (this behaviour was not consistent with the PC-Version)
i think the choosen Format should be strict. (priority over transparent option)
if you want to keep this feature as is - i requeste a white background option - aditional to the transparent Background.
thanks. kind regards - tom
@pascal can you please have a look at this or assign the responsible person - thanks
Hi Tom - I see that, thanks.
RH-64908 ViewCaptureToFile: Transparent background forces png format
thanks -tom
was this ever resolved? i just started using rhino on mac and when saving as a jpg (no transparent background options checked anywhere) it gives me a message about it needing to be a png for trans background and saves a png with white background…i want it to be a jpg like it used to be…
@pascal, ViewCaptureToFile on Mac still saves only PNG-format. Even when transparency is disabled.
When selecting JPG and Transparency off it says the followin gin the command line:
Command: ViewCaptureToFile
The Jpeg format does not support transparency. Set to Png format
@pascal
if read your internal discussion on
and
RH-42926
any update ?
workaround
my workaround for white background - .jpgs:
set a custom display-mode: copy render mode, set General - Shade Setting - Color and Material to “Object’s color” (which is the Layer-Color in default settings.
then viewcapture without transparency.
Same issue still, no way to create anything other than png with viewcapture. Really annoying as we use this a lot…
RH-64908 is fixed in Rhino 8 Service Release 9 on Windows.
NOT SOLVED satisfyingly:
Version 8 (8.9.24163.15302, 2024-06-11)
mac os x 13.5.1 intel
Transparent Info twice
the transparent option still appears twice.
Command-Dialog:
Checkbox - Transparent Background (png and tiff formats only)
Save As - Dialog
Checkbox - Transparent background for supported types
new Bug
At the current Release Candidate - something is broken with the file type. Seams like it is ignored ? I only get .png even if i choose jpg and add the .jpg extension in the dialog.
Expected:
  • only one Checkbox in the first command - Dialog
  • maybe the option should be named “No Background” - and the Behaviour is describted in the help ? transparent for png/tiff, white for others
  • the information, that only png and tiff support transparency - if Rhino starts to have this basic IT knowledge / information everywhere the interface will get quite annoying for advanced users. There is a (?) Help link at the lower left - so people can use it.
  • it should be possible to export a white/no Background jpg as described in the initial post. Maybe a quality-slider is a nice improvement.
thanks for looking at it again.
Oops. I should have mentioned “on Windows only.” We split the issue into platform-specific issues, one for Windows; one for Mac.
RH-82581 ViewCaptureToFile: Transparent background forces png format
is the one to watch on Mac.
Apologies for the confusion on my part.
