Is there a way to capture your view, but clipped to the page as set up in a Layout, or even a Detail frame?
Print to an image file would do this
Thanks Steve, it’s very slow though and has an inconvenient menu, compared to the ViewCapture commands
Hi Sven -
I suppose you could always use ToggleFloatingViewport
to float the layout and then resize that window and zoom so that the layout or detail fits the floating window.
Hi Wim, thanks for the suggestion. The good thing about a layout is that the dimensions/outline is defined by the paper or detail frame, and it would be great to use that as your capture setting.
