Dear all,
I am trying to offset several curves with same vertices sequence. When the base surface is flat plane, it works fine with “offset curve” componenet. But when I use “offset on surface”, the vertices sequence became randomly. It also happens with python script.
The problem is when I twisted base surface, the “offset curve” is not working since the base plane is no longer a flat plane.
This mostly happened at 0 to 1 degree. Occassionally happened after 1 degree.
Does anybody know why it happens?
Thanks
Chi
origianl curves end points
offset curve (in plane) component end points
offset curve on surface component end points
offset curve on surface(python script) end points
offset crv on srf.gh (18.4 KB)
