Offset on surface
Hi everyone,
I had trouble with the ‘offset on surface’ command. The curve (img 1) was divided through Tween curves, after which I applied the offset to the curves created. However, the component tells me that not all curves can be offset (img 2). Does anyone know where the problem might be?
img 1
img 2]
Offset on surface.gh (27.8 KB)
I have no recollection of that thread you linked to, or that cluster. And I don’t see any connection to “Offset on surface” :question:
3. Attach minimal versions of all the relevant files
Sorry, I don’t why but something happened during the uploading. Now I attached the file.
Related to the recollection of that cluster, I just deleted it, so it does not create any misunderstanding. Indeed it was useless for the following topic.
Uh… wow. That’s a lot of code for what appears to be a stack of identical planar curves, so why are you using OffsetS?
This is my limited understanding of Offset Curve on Surface:
OffsetS_2024Jan3a.gh (25.2 KB)
The structure of the algorithm is very long because it is part of a more complex system. I applied this process thinking first of all for NON planar curves. Not being able, however, to apply this offset to these curves, I tried to use a planar curve. The result didn’t change. In fact, some layers are “deleted” during the offset operation. (img 1-Tween curves and img 2-offset curves)
img 2-offset curves
In any case, I came up with a new solution that involves flipping the order of the components in the algorithm. Create the desired curve offset before applying the Tween curve. I don’t think it’s the most effective method, but for my project it should be enough.
Thank you so much for your patience
Yeah, I messed around without understanding your goal. It appears to me that the sharp point on your shape causes problems with standard Offset Curve and perhaps Boundary Surface. In any case, I still don’t see “Offset on surface” anywhere and in general, some of this code looks far more complex than necessary.
Giulia Riccardi_2024Jan3a.gh (29.3 KB)
P.S. The sharp point was definitely causing trouble. I applied a fillet to round it off and everything works better now! Maybe not quite what you want but an important lesson - avoid sharp points!
Giulia Riccardi_2024Jan3b.gh (39.2 KB)
P.P.S. Modified to fillet only the sharp point and leave the other two “corners” alone (white group).
Giulia Riccardi_2024Jan3c.gh (38.6 KB)
Thank so much! Your solution is pretty interesting and I think I’ll apply yours instead of mine :muscle:t2:
And thank you for your suggestion about sharp points!!!
It could be squared off instead of radius (fillet) to get rid of that sharp point in the curve.
