Vertical dimension orientation not consistent
Can someone please explain me why, sometimes, a vertical dimension randomly change its orientation?
See example below: the ‘20’ vertical label is sometimes flipped (1), sometimes not (2).
Is that a setting to be defined somewhere in the annotation style? I’m slowly going mad about this…
Another question: I expect the dimension label to always point outwards:
Is there a way to achieve that? The text position options seems to be restricted to ‘Above line’ and ‘In line’, no ‘Below line’ option…
It is exposed in Rhinocommon though…
https://developer.rhino3d.com/api/RhinoCommon/html/T_Rhino_DocObjects_DimensionStyle_TextLocation.htm
Thanks!
Nobody on this one?
Hello - can you please post a file that has one or two of these?. My attempts, so far, all look the same and … correct.
Hi Pascal,
Please find the file here: anotation_orientation_sample.3dm (139.4 KB)
Thanks!
Hi @pascal,
Did you manage to reproduce this issue? Can I help in any way?
Sorry to be insistent, but I consider this problem as a major one, as I’m currently not able to produce serious drawings for my clients. Nobody wants to pɐǝɹ stuff ǝʞᴉl this…
Here again one sample:
Ok, it seems to have something to do with the 'Orient text toward reader…" options.
Oddly, it does not seem to affect all dimensions the same way:
Is there a reason you don’t turn on Orient text toward reader?
I did find something to fix …
https://mcneel.myjetbrains.com/youtrack/issue/RH-54734
Regarding this: I made exactly the same wish post before:
RH-54734 is fixed in the latest Service Release Candidate
