VB to Python
Hi I am trying to convert the VB code to Python, it is producing some output but totally incorrect.
The VB code is from this link:
Both codes are below, any help is appreciated. Thanks in advance.
  Private Sub RunScript(ByVal P As List(Of Point3d), ByRef M As Object)
    If P Is Nothing Then Return
    If P.Count > 3 Then
      Dim ptsL As New List(Of point3d)
      ptsL.AddRange(P)
      Dim rnd As New random
      'create first mesh======================================================
      Dim msh As New mesh
      While msh.Vertices.Count < 4
        Dim ok As Boolean = True
        Dim addedIdx As Integer = rnd.Next(0, ptsL.Count - 1)
        'check if its not on line
        If msh.Vertices.Count = 2 Then
          ok = checkIfOnLine(msh.Vertices(0), msh.Vertices(1), ptsL(addedIdx))
        End If
        If ok = True Then
          msh.Vertices.Add(ptsL(addedIdx))
          ptsL.RemoveAt(addedIdx)
        End If
      End While
      msh.Faces.AddFace(0, 1, 2)
      msh.Faces.AddFace(1, 2, 3)
      msh.Faces.AddFace(2, 3, 0)
      msh.Faces.AddFace(3, 0, 1)
      msh.Vertices.CombineIdentical(True, True)
      msh.FaceNormals.ComputeFaceNormals
      msh.UnifyNormals
      msh.Normals.ComputeNormals
      While ptsL.count > 0
        Dim nextPtIdx As Integer = rnd.Next(0, ptsL.Count - 1)
        Dim nextPt As New Point3d(ptsL(nextPtIdx))
        'if inside then do nothing, else do mesh
        If (isPtInMesh(nextPt, msh)) = False Then
          Dim fList As New List(Of Integer)
          fList = seenFaces(nextPt, msh)
          fList.Sort
          For i As Integer = fList.Count - 1 To 0 Step -1
            msh.Faces.RemoveAt(fList(i))
          Next
          msh = createNewFaces(nextPt, msh)
        Else
        End If
        ptsL.RemoveAt(nextPtIdx)
      End While
      M = msh
    End If
  End Sub
  '<Custom additional code>
  Function checkIfOnLine(pt1 As point3d, pt2 As point3d, pttested As point3d) As Boolean
    Dim fine As Boolean = True
    Dim dist1 As Double = pttested.DistanceTo(pt1)
    Dim dist2 As Double = pttested.DistanceTo(pt2)
    Dim dist3 As Double = pt1.DistanceTo(pt2)
    If dist1 + dist2 > dist3 Then
      fine = True
    Else
      fine = False
    End If
    Return fine
  End Function
  Function IsPtInMesh(point As Point3d, ByVal mesh As Mesh) As Boolean
    mesh.FaceNormals.ComputeFaceNormals
    mesh.UnifyNormals
    mesh.Normals.ComputeNormals
    Dim box As BoundingBox = mesh.GetBoundingBox(True)
    If (Not box.Contains(point)) Then Return False
    Dim polyline As New Polyline()
    polyline.Add(point)
    polyline.Add(box.Max + New Vector3d(100, 100, 100))
    Dim x As Point3d() = Intersect.Intersection.MeshPolyline(mesh, New PolylineCurve(polyline), Nothing)
    If x Is Nothing Then Return False
    If x.length Mod 2 = 0 Then
      Return False
    Else
      Return True
    End If
  End Function
  Function seenFaces(ByVal point As point3d, ByVal mesh As mesh) As List(Of Integer)
    Dim sFaces As New List (Of Integer)
    For i As Integer = 0 To mesh.Faces.Count - 1 Step 1
      Dim actV As Vector3d = mesh.FaceNormals(i)
      Dim actFc As point3d = mesh.Faces.GetFaceCenter(i)
      Dim seeV As vector3d
      seeV = vec2Pts(point, actFc)
      If dotProduct(seeV, actV) < 0.001 Then
        sFaces.Add(i)
      End If
    Next
    Return sFaces
  End Function
  Function vec2Pts (pt1 As point3d, pt2 As point3d) As Vector3d
    Dim vec As New vector3d(pt2.X - pt1.X, pt2.y - pt1.y, pt2.z - pt1.z)
    Return vec
  End Function
  Function dotProduct (v1 As Vector3d, v2 As vector3d) As Double
    Dim dot As Double = (v2.X * v1.X) + (v2.y * v1.y) + (v2.z * v1.z)
    Return dot
  End Function
  Function createNewFaces (pt As point3d, mesh As mesh) As mesh
    Dim naked As New List (Of polyline)
    naked.AddRange(mesh.GetNakedEdges)
    Dim edges As New List(Of line)
    For i As Integer = 0 To naked.Count - 1 Step 1
      Dim actN As New Polyline
      actN = naked(i)
      edges.AddRange(actN.GetSegments)
    Next
    Dim newM As New mesh
    For i As Integer = 0 To edges.Count - 1 Step 1
      Dim newTriangle As New mesh
      Dim actE As line = edges(i)
      newTriangle.Vertices.Add(actE.From)
      newTriangle.Vertices.Add(actE.To)
      newTriangle.Vertices.Add(pt)
      newTriangle.Faces.AddFace(0, 1, 2)
      newM.Append(newTriangle)
    Next
    newM.Vertices.CombineIdentical(True, True)
    mesh.Append(newM)
    mesh.Vertices.CombineIdentical(True, True)
    mesh.UnifyNormals
    Return mesh
  End Function
  '</Custom additional code>
import Rhino
import System
import System.Collections.Generic
def checkIfOnLine(pt1,pt2,pttested):
    dist1=pttested.DistanceTo(pt1)
    dist2=pttested.DistanceTo(pt2)
    dist3=pt1.DistanceTo(pt2)
    if dist1+dist2>dist3:
        fine=True
    else:
        fine=False
    return fine
def isPtInMesh(point,mesh):
    mesh.FaceNormals.ComputeFaceNormals()
    mesh.UnifyNormals()
    mesh.Normals.ComputeNormals()
    box=mesh.GetBoundingBox(True)
    if not box.Contains(point):
        return False
    polyline=Rhino.Geometry.Polyline()
    polyline.Add(point)
    polyline.Add(box.Max + Rhino.Geometry.Vector3d(100, 100, 100))
    x=Rhino.Geometry.Intersect.Intersection.MeshPolyline(mesh,Rhino.Geometry.PolylineCurve(polyline))
    if x==None:
        return False
    if len(x)%2==0:
        return False
    else:
        return True
def seenFaces(point,mesh):
    sFaces=System.Collections.Generic.List[int]()
    for i in range(0,mesh.Faces.Count - 1,1):
        actV = mesh.FaceNormals[i]
        actFc = mesh.Faces.GetFaceCenter(i)
        if dotProduct(seeV, actV) < 0.001:
            sFaces.Add(i)
    return sFaces
def vec2Pts(pt1,pt2):
    vec=Rhino.Geometry.Vector3d(pt2.X - pt1.X, pt2.Y - pt1.Y, pt2.Z - pt1.Z)
    return vec
def dotProduct(v1,v2):
    dot=(v2.X * v1.X) + (v2.Y * v1.Y) + (v2.Z * v1.Z)
    return dot
def createNewFaces(pt,mesh):
    naked=System.Collections.Generic.List[object]()
    naked.AddRange(mesh.GetNakedEdges())
    edges=System.Collections.Generic.List[object]()
    for i in range(0,naked.Count - 1,1):
        actN=Rhino.Geometry.Polyline()
        actN=naked[i]
        edges.AddRange(actN.GetSegments())
    newM=Rhino.Geometry.Mesh()
    for i in range(0,edges.Count - 1,1):
        newTriangle=Rhino.Geometry.Mesh()
        actE=edges[i]
    mesh.Append(newM)
    mesh.UnifyNormals()
    return mesh
if len(P)>3:
    ptsL=System.Collections.Generic.List[object]()
    ptsL.AddRange(P)
    msh=Rhino.Geometry.Mesh()
    rnd=System.Random()
    while msh.Vertices.Count < 4:
        ok=True
        addedIdx=rnd.Next(0,ptsL.Count-1)
        if msh.Vertices.Count == 2:
            ok=checkIfOnLine(msh.Vertices[0], msh.Vertices[1], ptsL[addedIdx])
        if ok:
            msh.Vertices.Add(ptsL[addedIdx])
    msh.FaceNormals.ComputeFaceNormals()
    msh.UnifyNormals()
    msh.Normals.ComputeNormals()
    while ptsL.Count > 0:
        nextPtIdx= rnd.Next(0, ptsL.Count - 1)
        nextPt=Rhino.Geometry.Point3d(ptsL[nextPtIdx])
        if not isPtInMesh(nextPt, msh):
            fList=System.Collections.Generic.List[int]()
            fList.Sort
            for i in range(fList.Count - 1,0,-1):
                msh.Faces.RemoveAt(fList[i])
        else:
            pass
            msh=createNewFaces(nextPt, msh)
    M = msh
It’d help with debugging if you also upload a Grasshopper file that demonstrates the error.
On a sidenote, I’d highly recommend implementing MIConvexHull for computing fast, clean and stable 2D/3D convex hulls. I’ve been using that on several projects recently (including this one), where the standard Grasshopper convex hull solver would fail. Here’s a quick example that should work if you unzip the MIConvexHull.dll to the default Grasshopper libraries folder:
230425_ConvexHull3D_MIConvexHull_GHPython_00.gh (4.5 KB)
MIConvexHull.zip (15.9 KB)
I hear you, that’s also always a primary concern for me.
Anywho, you should probably still upload a Grasshopper file to debug :wink:
Hi Anders,
Here is the gh file, improved a little bit more but still could not finalize it.
VB_Python.gh (10.2 KB)
